Port Help
hoppinAltima
So i just built a new sub box for my car and i need some help with the port tuning I want to see if my number are correct.
THe box specs are 6 ft3 net* and i have 2 round 2.75 Diameter ports.
Can someone run the number and see how long it should be. THe website i used i think carstero.com said to have them around 4" and i dont think that right because its not hitting the lows.
At 4" long with those ports it is tuned right around 30 hz. Your problem is that you don't have enough port area for it to get that loud at all. What size and how many subs are you running in the box? My advice is to replace the ports with 4" or even 6" ones depending on what your using in the box and also how much power is being used.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
oo so the ports are too small? im running 3 12" off a 2000 watt amp. I think i could fit 4" diameter ports, thats what you meant right? but how long would they have to be?
yeah man make them ports alot bigger you gonna have port noise out the ass. lol but its a simple fix since you used round portss
NOVEMBER 2008 SYSTEM OF THE MONTH!
ORIGINAL YUKON BUILD!
TEAM DTF
TEAM Rival Mobile Electronics
TEAM Xs Power
94 yukon
12 Rival C15s
50+ Boston mids and highs
15 Xs power D2400
600+ ft of 1/0
10+ gallons of resin
99 Silverado.
4 15" Treo SSX
Stetsom 14k2d
5 CD tech batteries
155+ daily
Team DTF
"did you just drive past my house in your stupidly loud car. if it was you, you knocked a vase off my fire place."
For 3 12's I would reccomend 2 6" ports 20" long and that would tune you to 32 hz, but since you said that you only have room for 4" ones you could do 2 at 8" long and it will tune you to 32 hz as well and definately increase your output. You may want to consider building a new box so you can add more ports or if you could even squeeze another 4" one in it would help out a ton. If you did 3 4" ports at 13.5" long it would keep the tuning at 32 hz and probably be even louder than just 2 ports.
1 XS Power D3100
Audio Control LC6i
Stock Deck
  • Who's Online   0 Members, 0 Anonymous, 4616 Guests (See full list)
