Quick Battery ?
In Front: Optima Yellow Top
In Trunk: Kinetik HC800
0 guage from Yellow Top to the HC800, Off the HC800, A Rockford Fosgate T-1000
Will a 110 Amp Alternator be enough for this? AND do you think i even need the second battery?
Yes on the 110 amp alt, and yes on the second battery. You can never ever go wrong when adding a second battery to a car. Unless it's a group 8d battery that is somewhere like 3200 CCA and a stock alt will never be able to charge something like that. As far as the Kinetik 800 goes it's not a huge battery and the stock alt will be fine on it.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
so the alt will have no problem charging both and does it need an battery isolater?
No need for a battery isolator. All that does is allows the alt to charge one batt while the amps run off the other and then when the secondary battery needs charging it kicks the alt there and helps out. It's better to have the alt charging both at the same time because your using both at the same time. It's really like just having one large battery when you run two in parallel.
1 XS Power D3100
Audio Control LC6i
Stock Deck
I would have to say that the alternator would have a hard time keeping up with the RF T10001bd. I say this because my old RF T1k would draw damn near 150 amp all the time. An if the alt is only putting out 110 (which is the same size on my car) it will be hard to charge the batteries if you bang it a lot plus your car is going to draw amp from the alt too. I could see your car drawing 20 amps (just guessing, maybe more) and the T1k drawing atleast a 100 amps if you listen at a normal volume.
The batteries are fine, the alternator is questionable.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
