i have these 2 amps TEK 50.2 i bought 2 from a friend for very cheap..i looked em up and it says it can be used for subs and for mids/highs.... keep in mind i barely just installed my first set up still kind of new to this....
i got a tricky question...to power it up can i just get a smaller wire most likely 8-gauge and connect it to my current amp then from that amp to the tek amp and then the same with the REM and i will just get a new ground...or would that be too "ghetto" or would it be better just to cross/bridge it?
LMK...
heres pix my good camera is dead so bear with me..
^^ left to right 12v-REM-Ground
Edited by Red-navi-916
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
okay. then i will probably just run it a different way..would the fuse rate matter.. one being 20 and the other being 2 40's?
BUILDLOG
distro block is what your needing
R.I.P!
(Nov-29-2009)
92 explorer
current build
