im fixing to build a new box, it will be 10cuft net with 144sqin of port. question is should i run a single 12x12 port, or 5 6in round ports?
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
I don't think you will need that many round ports. You should be good with four 6 inch ports.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
dont you want the same port area either way? 4 6in ports is only 113sqin.
You won't need quite as much port area when using a round port over a slot port. With 4 6" ports that comes out to be 11.3 sqin of port per cuft and that is a very good ratio to have. If you were to have 5 6" ports that would be 14.1sqin per cuft and is a bit on the high side for a round port.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
no especially if u use aeroports
8-12sqin is fine for aero
idea behind it is that in a slot or square port, the 90 degree angles cause some turbulence and "dead space" that isnt really part of the working port surface area
in a round port, especially aero, turbulence is reduced something like 50% from slot/square without roundover/flares which allows for smaller port surface area since almost all of it is being used due to the flaring... thats my understandin
4 6" ports would be adequate and sweet, they are beasts... ~9.5" in diameter
Edited by decafcappucino
maybe, to many variables
for 10cuft
if you do square, stick with 14-16sqin... but the port will take up more internal volume than round port
stick with the 4 6" for 10cuft if aero, 5 6" if regular pvc
it would be regular pvc, if it works and i like it then i'll spend the money on aero's. you seem to have experience with round ports, how do they sound daily compaired to slot
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
You can't compaire aero's to pvc. Its not a fair comparison.
I general rule... aero port require 25% less port area vs. a slot.
Ex: 100 sq inch slot to 75 sq inches of aero port
I do box designs.
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
