Straping Amps
fast85_gt
not sure bout the saz but my powerbass you take your
+ from sub and run that to the + of amp A
- from subs and run that to the + of amp b
take both - from amp a and run that to - of amp b
then put amp A in master/ Amp B in slave run your rca and your done
R.I.P!
(Nov-29-2009)
92 explorer
current build
then you just adjust the gains on the master or how does that work
Speaker wiring is the same on the Sundowns but there isn't any Master/Slave switch. Just run the Br out rca of the master amp to the Br in of the slave amp. You only have to set the master amp. The slave will automatically follow. With the pair strapped @ 2ohms they will put out 6kwatts total. Check this link for pics of strapping procedure.
http://www.soundsolutionsaudio.com/forum/i...?showtopic=7406
thanks derrick
On my Memphis amps, you have to buy a bridging module for the RCAs and gain match the amps prior to wiring them as listed above. There's no m/s options on them so each amp gain has to be set prior to strapping.
I know you wanted to know about the SAZ, but just throwing my .02 that not all amps are the same if you ever change them out. ;)
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
alot of amps that dont have br or master slave you need to use a bridging module
or you can use a maxxlink i think
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 843 Guests (See full list)
