I'm wanting to build (Try) a T-Line enclosure for a 8" woofer. I really have no reason why, just to see what all the hype is about. :)
What 8" woofers meet the criteria T/S parameter wise??
I would like to try a 8" CVR in a T-Line but not sure if its do-able.
Would anyone want to show me a design or help me design an enclosure??
My box skills kinda suck. :D
Thanks for any help!
Derp.
You can do it with a CVR, but it doesn't have the best parameters. You'll need a 6.25' line with 40in^2 of "port" area.
See thats the thing I somewhat understand what your saying, then again I don't. Thats mostly where I need help at. :)
Derp.
Here, I hope this helps a little. If you need a cut list I can do that too, just give me a shout. The red line represents the "t-Line" and its 6.333ft long. The "port" is 4"x10" all the way along the "line." Those dimensions are using 3/4" MDF.
Edited by duct_tape123
This is what I found
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Get me some specs on them. I need FS, QTS, and QMS. Do you want a design for two in the same box, or two seperate boxes?
Could you do one for each? A single and double 8" enclosure?
Thanks for the help with the design Duct_tape!! :friends:
But what is that box tuned at?? And it is for the CVR correct?? LOL
Thanks again.
Derp.
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
