Ok, a few months ago my home was hit by lighting. My computer which was not on a surge suppresor (i know stupid) got hit, along with a few other low voltage items. My computer still accesses the net, but all of the usb ports (both in the front and rear of the machine) and sd card reader are dead. Any ideas? Is this worth fixing? Money as usual is always tight.
I have already tried using a usb hub so i can get my new printer up and running (the old one died after the lighting hit). I thought I could plug the usb hub where the keyboard plugs in and then feed my other accessories off the remianing hub areas. This did not work. The keyboard would not function wired this way.
Any ideas?
Computer seems to work fine still burn cd and dvd, and can connect to net, no loss of speed, just lost all power to usb ports, and mmc/sd slot.
gonna have to replace the motherboard.
WHat's the make and model of the computer?
ICH5/ICH5R has a problem, where latchup damages part of the chip.
The results are, Device Manager shows the USB ports, all in order
and correct, but each USB port is "deaf". And the reason for it,
is the power source feeding the I/O driver, burns out, leaving
the physical layer of the USB port non-functional.
+5V -----/ /--+ <--- broken power path
v +5V Physical
Logic Block ------------ I/O driver --------- D+ Layer
Works OK --------- D- Of
GND Port
When the lightning strikes, it can induce a transient on the
physical layer, and damage it. So it is possible the port
may have failed, because of damage to the +5V,D+,D-,GND spot.
It is even possible the +5V path to the port is what failed,
and you might want to check that a mouse lights up when plugged
into the port. The port won't function, if the +5V on the
connector is no longer working. Some of those are fuse protected
(but the fuse is a Polyfuse type, which normally never
needs replacement, and the fuse recovers after it cools off).
If you purchased the exact same motherboard, you should be
able to drop it into place and continue using it. Depending
on what other devices are damaged in your computer.
If the lightning strike is very close, the effect can be
powerful enough to leave physical effects, like burn marks,
charring, chips with lids blown off. But even a weaker
strike, can still leave invisible effects.
Another thought that occurs to me, is you could purchase
a USB2 PCI card, and use that to get some USB ports. That
won't necessarily help with editing the contents of the BIOS
using a USB keyboard, but for other USB purposes, it would
give you some working ports, without replacing the motherboard.
v +5V Physical
GND Port
The low voltage side of my furnace took a nasty hit and a large section of the circuit board was black and brittle. I have opened the computer but did not see any black or burned places. I did have a large section of my tree and ground where is looks like someone placed a landmine...LOL.
