ok let me break it down.
I used 1 massive audio p3000.1
3000rms x 1 @ 2ohms
1500 x 2 @ 1 ohm each channel
1000rms x 2 @ 2ohm each channel <<< This is the only config I was able to use since my subs are dual 4. and I can't wire the subs to a 1ohm load bc that will most likely fry my amplifier.
3000rms x 1 @ 2ohms
if i were you i would run the amp mono in a 4ohm load just series wire the subs try it and c if it hits harder
Nice truck & setup man.
What are you gonna cover that Humongous box in?
Good luck on the 150 too.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Thanks. I was planning on bedlining it instead of carpeting it. I heard that carpet will restrict air flow and probaly loose some db's. not a lot of db's just .1db or so but I would rather be on the safe side. I'll keep everyone updated if I ever get that 150. I know its not easy, but it's possible. but first I'm going to throw all 6krms, and if I get that 150 I'll do the bedlining. If not then maybe a new box and see from there.
Yes they will  ;D , audioque is built from the same buildhouse as digital designs, thats if you didn't know. They compared the hd3 to the dd 95 at one time, the hd3 was able to keep up with the 95 at 3k, but at over 3k the dd 95 performed better. So I know for a fact it can handle 3krms. Hearing it from the owner himself is also another thing.
So if they're built in the same factory and comparable to the DD subs....which AudioQue subs would you say compare to the DD3500 series??? I'm looking for 2 3510's, but if the AQ's are just as good/the same thing, why waste money on a name???
  • Who's Online   1 Member, 0 Anonymous, 1361 Guests (See full list)
