so i got in some new subs... four memphis pr 12's, i need some help on the port size/depth, i'm clueless here
box will be 44"x24"x15 roughly 9ft^3 before anything, i'm aiming for subs up, port back (pic) i kinda wanna do a port in the center like steve so it works inbetween the subs, doesn't have to, we can go under the subs also with a wide port
roughly how much port area should i go for the four 12's? i'm aiming for 32-34hz, i'll go a lil over
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
http://www.carstereo.com/help/Articles.cfm?id=31
input your dimensions and it tells you your port size, i would do aero ports but you can do a slot port if ya want.
I put in 9ft^3 with 4 4" round ports tuned to 32 hz and they will each have to be 11.77in long
or
2 6" round ports at the same freq and they will have to be 12.15" long each
or
6"x12" port tuned to 32 hz and it will have to be 8" long
there are many different combo's, just play with it and see what works with your box.
Oh and you might wanna learn how to work with google sketchup..makes your life much easier.
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
Don't put the port in the middle of the face. Unless you're moving a hell of a lot of air relative to the box size it makes it less effective, you have high pressure on the walls around the port but very low pressure at the actual port mouth.
10.x volts fo' life!
why would that make a difference? does the placement really matter, the air is gonna move in and out regardless where the port is?
and that is awesome, thanks alot, kinda with going with what's ahead, how would this be if it was facing back right inbetween the subs? i know the sub up port up isn't as great
Alpine CDA-9883
Kicker ZX350.4
ttt
any other opinions on this? if not box is being built tomorrow with sub in the middle
Alpine CDA-9883
Kicker ZX350.4
Think about the pressure (actually pressure variation but hey...) inside your box. It's going to be highest in the corners because that's where the waves meet.
In terms of on-face pressure it's going to be lowest in the middle of the face unless you have some funky design directing the pressure.
Unless your box is really small relative to the displacement of the cones moving it's more efficient to have it on an edge. There's some technical BS like laminar airflow but I won't go into it.
Suffice to say that the exact same box metered very differently when we moved the port from the middle of the face to the bottom of it.
moved the port to the bottom and added 45s on the corners and some dowel supports
here are some dimensions:
oh and the port it 8" deep
Edited by eliassami5
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
What about Port Area?
9ft^3 of volume, and 4 12's?
Wouldn't he need 12-16 square inches per 1ft^3 of volume? ... thats like 108-144 square inches of port area needed.
Edited by m4a3master
not to highjack your thread, but does anyone have the equation for port length if you have port area and all?
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
