I am going to run dual alts , dual batteries on an 01 Tahoe. What is the best way to wire it to keep seperate alt, batt for stereo. Will the amps off a 220 amp alt straight to second battery, blow the fuses on amps. Hooking up alt to side post terminal, and amps off top post.
Edited by 11BangBang
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
nall you should be fine. use 1/0 and run a 300 amp fuses. regardless of using the side or top post ...... internally they are both connected.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
if your doing a setup on 12v wire it all together- if your doing 16v then go about separate bats and alts for system and car.
-Drew
uhoh_45 said:
i asked a simular question a lil ways back and this is what i got should help
I thought running parallel you needed to exact same batteries, mine are almost the same, one red top optima on the truck, and a second yellow top deepcycle, I was going to use for the stereo. Are theses batteries compatable for wiring parallel. And if my other battery is in the back of my Tahoe what is the best way to run them together.
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
How should i wire them the best way for 12v system, I am a noob to dual set ups
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
+ on the front battery to the + to the rear battery(s) ........ fuse no more than 18 inches from the front battery and no more than 18 inches before the rear battery(s). you should be good. you'll be good with the yellowtops although for their price you could get kinetik or powermaster.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
What size fuses should I run on power wire to rear battery
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
If batteries are parallel does it matter if each alternator is run to seperate batteries. Just to confirm it will not hurt the alternators to connect them to each other then run them to the battery.
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
