Fried Amp?
rizzy71
A friend asked me if I could look at his amp because it wasnt working. I took it appart and it looks totally fucked. im not sure what he was running off of it but he had peiced together 18 gauge wire for power and ground, lol. any help would be nice.
thanks in advanced.
BRENT
1997 GMC Yukon
1-DC xl18"
Stetsom 2K5E
3-Kinetik HC1800's
1967 Pontiac GTO
it all looks like corrosion to me, ive seen alot worse work perfectly fine
thanks james. any idea what can be wrong with it then? the power light came on when i hooked it up in my car but there was no output from it. the power light stays on for a while but it goes into protect after a while.
BRENT
1997 GMC Yukon
1-DC xl18"
Stetsom 2K5E
3-Kinetik HC1800's
1967 Pontiac GTO
That brown shit all over the solder points is probably just excess flux. If you heat it with a soldering iron it will bubble and boil off.
I can't see anything obviously wrong with it from the pics, check the output BJT's (the big transistors) in case it's one of them but it's probably some shitty little part in the signal path that's given up.
I assume you don't have access to an oscilloscope? You're kinda shooting in the dark without one.
10.x volts fo' life!
would my local audio shop have one? or do most not? i can get one from my old highschool but im not sure what to look for.
BRENT
1997 GMC Yukon
1-DC xl18"
Stetsom 2K5E
3-Kinetik HC1800's
1967 Pontiac GTO
Could be worth asking.
You could just follow the audio signal from the RCAs and see where it disappears but it could be a problem with the protection circuit or something else in the amp.
Sometimes it's easier to repair an amp when it's nice and blown up and you can see everything that's wrong with it :lol:
  • Who's Online   0 Members, 0 Anonymous, 707 Guests (See full list)
