Starting Battery
Guest KyleCannon
both of them would work fine in my opinion, depends if you have a system or not, i would still personally go for the PM XS Deep Cycles.
word is they are the same battery so get whichever works for your pocket
the S comes with terminals and case though
So they will both have the same power? btw I will have a system soon but only around 1200rms, It also needs to be able to turnover my v6 in the winter when its like 10 degrees.
Guest KyleCannon
Those should be fine, when in doubt, get the step up! :D
Or I was also considering just keeping the stock battery under the hood, and adding a powermaster d925 out back, but I dont want to fry my 105 amp alt.
The red one is an S.L.I. ( starting, lighting, ignition ) type designed for cranking an engine over. Hence the ''s'' in the model #. Good for quick, high burst current for engine cranking.
deep cycle will work, but is designed more for extended or continuous pull for longer time e.g. trolling motors for example.
But I am looking for a battery that will turn the motor over in cold conditions, and still have power to power about a 1000 watt audio system.
  • Who's Online   0 Members, 0 Anonymous, 1020 Guests (See full list)
