I don't think you have the room to build a horn for 2 18's. Pete from PWK Designs had a rear-loaded horn for his 2 15's and that was a full wall.
If you want to get NEAR 156dB your only option is a wall really. You could possibly do ok-ish numbers with a box like David's old Mustang box but it will still only be low 150's.
10.x volts fo' life!
Ohh. If I did have enough room for a horn how much db you think I could pull then???
Very Very Soon 2 Come???
(1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof)
(4):15'' Orion Hcca's
(1):Stetsom V 14K2D
(6):Kicker PKD1 (Ampkit)
Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF
(8):Screws for terminals (Better solid connection no leaks)
(1):Dynamat xtreme license plate kit
(1):Kenwood eXcelon KDC-X492
(3):300amp HO Alternators
(4):Kinetik HC 3800 Batts.
(1)Rockford Fosgate Power T8004 (For Mids & Highs)
(4)Rockford Fosgate Power T162S (Mids & Highs)
(3):Kicker PKD4 Ampkit (For Mids & Highs)
(1):Kinetik HC 1800 (under the hood or yellow top)
(1):Viper 5701 (p/n 5202V) ALARM
Big III will be done (beefing up my electrical system) etc.
Goal:154.9db-159.5db
Who knows. Horns are usually made for high efficiency over a large bandwidth.
Probably still into the 150's but it's pointless to consider, a bass horn for 18's would be ENORMOUS.
Out of interest, have you ever even competed before? You're talking about a HUGE system and I have a sneaky feeling you don't really have the basic knowledge required for a project like this...
No I have'nt competed in any real db drags or anything yet but I plan to. But yes I know the basic knowledge I know alot about audio.
(1):Stetsom V 14K2D
Goal:156.4db-158.7db
Why did you pick such precise numbers?
Maybe if you had four huge 15s using every last bit of space tuned properly on 20k+ watts, you'll hit your goal on a burp, but otherwise good luck.
Be prepared to spend big money.
x2
Need an install? Hit me up.
[email protected]
x2
Ohh dont worry I will!!! BTW I like your builds :)
(1):Stetsom V 14K2D
yeaah this aint going to hit higher then a 152 tops but it should get loud on the music
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well how much more db you think I'll hit walled then????
(1):Stetsom V 14K2D
this seems like a huge project. 156 is like 4x louder than 150 or some shit (what is it.. for every 3db its twice as loud?) make sure to take lots of pictures and vids
you ain't been bizzy til you've been wit jizzy.
Vehicle:: 2005 Saturn Ion
Headunit:: Jensen 9312HD
Speakers:: RE SE Coaxials
Subwoofer(s):: (2) 15" RE SEs
Amplifier(s):: Audiopipe AP1500.1D
Audiopipe AP1504
Enclosure:: Sealed
Wire: KNU KONCEPTZ 1/0
Battery:: Kinetik HC600
you cant just guess what you'll hit
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
