SPL2K Posted February 14, 2009 Report Share Posted February 14, 2009 He's already at 1 cube. You honestly think that it should be smaller than that? Yes...i had .88 cu ft per pair of solo x 10's and that was before displacement. Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA. Link to comment Share on other sites More sharing options...
daddy_j Posted February 14, 2009 Author Report Share Posted February 14, 2009 looks nice, so what did those 4 10s hit? and was it on 12volts or 18volts? I see you have a lot of power there. Link to comment Share on other sites More sharing options...
Justin Posted March 14, 2009 Report Share Posted March 14, 2009 I just pick up a solo x 10 for $30.00! what kinda of number will one do? Also wondering if you would be interested? 99 2dr Blazer Kenwood KVT-614 SounDigital SD16k 4 Fi BTL 18s 4 hertz high energy 6.5s comps 4 stock ad244 alts 6 g31s batts 8 runs 0ga Link to comment Share on other sites More sharing options...
Colin - STAPUFT Posted March 14, 2009 Report Share Posted March 14, 2009 Why not 45 the corners and resin the inside of the box? Then sand it down where it is slick as glass? That won't be much $$$, just time and elbow grease. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back. Link to comment Share on other sites More sharing options...
Boon Posted March 16, 2009 Report Share Posted March 16, 2009 Why not 45 the corners and resin the inside of the box? Then sand it down where it is slick as glass? That won't be much $$$, just time and elbow grease. If you pour lots of resin you don't even have to sand it, just make it thin and let it pool... 10.x volts fo' life! Link to comment Share on other sites More sharing options...
