I hooked up my old system today in a car. Had the same system hooked up about 2 weeks ago and it worked fine. but anyway the woofers play no music at all just a pulsing tone. they stop when you disconnect power or remove rca's from the amp. what is the problem
Ah, I just recently sent my amp out for a similar problem. Does it just pulse once when it powers on or does it continue to pulse?
EDIT: Watch your protect fault light and watch the subs while they make the sound and see if they move slowly. Be a little more descriptive about when it's happening.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
i had this happen. it was my preouts on my headunit.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
i was gonna say a ground problem but signal interference fits alot better with the problem.
Yeah. That's why I asked if it was just once or repeated.
Make sure your RCAs are seated properly in the back of the HU or try some new ones. I'm almost willing to guarantee that's the problem. If you have a line driver or bass booster, try turning it down because those cause funny things to happen if your gains aren't set right.
EDIT: Seen this exact problem before. That's why I told you to watch the subs.
Edited by Neo_frog
[email protected]
sounds like an amp problem. try hooking up a cheap sony amp or something and see if it still does it.
  • Who's Online   0 Members, 0 Anonymous, 926 Guests (See full list)
