i was gonna say a ground problem but signal interference fits alot better with the problem.
sounds like an amp problem. try hooking up a cheap sony amp or something and see if it still does it.
I think you are just making things up in hopes that its the problem. I doubt its the amp itself, its probably more along the lines of the RCA connections or the HU ground not being so hot. Try grounding your RCAs and see what that does.
so what would be the best way to go about fixing this problem. try diff rca's and change the gain
Well just try one thing at a time to rule things out one by one.
Try new RCAs
Turn any line drivers, bass boosters, eqs, etc down a hair or leave that volume and turn the amp gain down
Try a different amp.
That rules out the most likely possibilities.
Need an install? Hit me up.
[email protected]
the rca's are brand new stinger. just in from darvex. not running any line drivers or bass boosters so think it would be the gain
Well, not really just the gain. I meant if you DID have those things in series with the RCAs, then your amp gain or accessory gain could be throwing a bogus signal. But that's only when they're together.
Just cause they're new doesn't mean they are good. I'd try an old crappy set real quick. If that doesn't fix it, try moving that RCA from SW to Rear on the back of the HU.
If that doesn't fix it, then it could be a bad amp, but I doubt you'll get this far.
**meaning you shouldn't have to go this far. ;)
Edited by Neo_frog
[email protected]
ok well hope this works ill get on that in the morning
What kind of HU do you have?
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
  • Who's Online   0 Members, 0 Anonymous, 740 Guests (See full list)
