I was wondering if its important to use wire terminals for the wire that goes into the amp. Should i use terminals or is it ok to just stip the wire and put it in the inputs? also how does this speaker wire work? http://www.sonicelectronix.com/item_3944_Kicker+SW1220.html# Is it one wire or is the blue positive and gray negative?
1 DC lvl 4 15"
1 Hifonics BXi 1608D
3.2ft^3 Box tuned to 32-33Hz
Knu Kolossus Fleks Kable 1/0
Knu Karma SS 8 Gauge Speaker Wire
Kenwood eXcelon KDC-X493 Head Unit (coming soon)
Kenwood mids + highs (coming soon)
Build
It depends what the amp's terminals are like.
Most big amps these days use insert-style terminals so you just strip 1/2" of wire, shove it in and do up the screw to hold it in.
If the amp uses terminals that will take a ring/fork/spade connector you should use one to make sure you have the best connection possible.
10.x volts fo' life!
Kicker wire is a twisted pair. two wire come in the plastic shell. yes one is for pos and one for neg
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
you can use either or for positive or negative just as long as you match the negative on on to negative on sub... and it depends on the amp like said above but the little boot they show which kinda look like half a utter just keeps the two wires apart from each other it looks like and cleans it up some.
So how would i use that kicker wire to wire a 2ohm DVC sub to 1 ohm?
1 DC lvl 4 15"
Build
