most amps work best in about 65F. so if they go too low it wont be a good thing.
The FETs work much much much better at like 0 degrees ;)
Check out the datasheets for some big FETs, the current handling at 75 degrees C (which is the spec they build around) is usually ~1/3 the handling at 0.
10.x volts fo' life!
Like many of the major car audio companies, I'm sure that this has already been brought up in their design room. Just like RF and their "Bright Idea" thing, I bet somebody already submitted somthing similar to that for a cooling idea. But I still want to see how this does in real life, and i agree with B, you are a smart ass dude :D
Eclipse cd7000
I think it's a pretty nifty idea nonetheless. I'm interested in seeing how they perform.
Forevrbumpn keep us updated if you have good results!
Need an install? Hit me up.
[email protected]
Well, if its not the best idea to cool amps with, well, maybe I will line my fireplace with these, and use the heat to power my TV ;-)
They also act as a power source too
