hm- i've been wanting to change that fuel filter for some time now...
the only thing that turns me away from Air/spark/fuel and most pre ignition issues is that it revs Amazing in N or P, if it was in the fuel line or a spark issue then it should also fail in those two gears right?
:help:
-Drew
nope totally diff, no load on the engine.
i'll set out in the direction of the fuel filter and go from there- fuel pump is way to expensive for lil me so hopefully that is fine
-Drew
uhoh_45 said:
Fuel filter is an easy and cheap replacement, but I know with my truck when I ran my Old HO Alt that @ idle the truck would act like it was going to die.. It was from no output @ idle...
Team Ampere Audio
what make, model and engine is the car?
it sounds to me like mass airflow sensor or the tps. but it also sounds like it could be the filter but if the cat was bad you wouldn't be able to rev at anytime.
just me 2cents: also when the check engine light comes on don't try and get it to go away! try and find someone with a scanner and see what the codes are!!
i know autozone up here will put the scanner on it up for free!
Kenwood KDC-X792 Mb quart 4x6
Mb quart 4x6 front stage
MB quart 3way 6x9
0/1 ga. Rockford wire
The Big 3. 0/1 ga.
Rockford t1000bd broke
RE SE 2ohm DVC 15"
4 cu ft ported enclosure
I'll ask kragen if they will run codes for free- just picked up the fuel filter and getting to work! :)
-Drew
Fixed :ph34r:
-Drew
Congrats
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
thank you sir! :yahoo:
i'm on my way to return the Fuel filter now
-Drew
-Drew
return it? lol. what?
Team T3 Audio
Team Sundown Audio
Team O.B.M
