Symptom:
When accelerating it will randomly lose power off an on (like a severe warble)
Notes:
only happens in L 2nd and D NOT N or P
Auto Transmission with enough fluid
severity of the warble increases and decreases, when most severe the "Check Engine" light will come on. When i pop it into N and give it a rev the Check Engine light goes away.
Honestly I'm pretty baffled at the whole thing- it feels like there are lil gnomes in my car fucking with shit as i drive around!!!
:help: :help: :help: :help:
-Drew
(as long as it rolls i will be at AR- obviously BR is in Park so i can keep the alts going full tilt without issues :) )
Edited by Noobtastic14
uhoh_45 said:
try using seafoam. its a liquid product that helps clean up engine composits, injectors, ect. it worked a number on my car so good, it hepled it pass smog. no bad for $5 bucks.
i don't think so- it happens with or without system on and it was VERY sudden.
rolled home and it was fine- left and it was horrible
Can i get that seafoam at local automotive stores? i might give it a whirl even if it doesn't fix the grand problem it sounds like a good idea anyways :)
-Drew
does it get worse with harder acceleration vs lighter accel? makes me think clogged cat as of right now.
also kinda sounds like misfire due to improper air fuel ratio caused by many things air, fuel & ignition related
check the basics and easy stuff first
hm- i've been wanting to change that fuel filter for some time now...
the only thing that turns me away from Air/spark/fuel and most pre ignition issues is that it revs Amazing in N or P, if it was in the fuel line or a spark issue then it should also fail in those two gears right?
:help:
-Drew
ill x2 the Cat and the fuel filter
maybe the EGR valve if your car has one or the TPS, IAC sensors
DC.jpgDC POWER
