8 12's
rookie023
do you think its possible to fit 8 kicker cvx 12's in a tahoe behind the 2nd row either firing up or walled off with just a flat wall still having room for a port and stuff to spec? im just weighing my options.. thought id ask. thanx
2002 Chevrolet Tahoe
4 Kicker CVX 12's (under construction)
Why not measure yourself?? :rolleyes:
i mean ive measured.. im just not really good at port size and all of that. i have 4 back there right now firing up and i have 2 more just sitting still in their boxes waiting to have something done with them but ive been thinking about amps and i dunno what to do with 6 dual 4 12's. get 3 1 ohm stable amps? or i could get 2 more 12's and get 2 t40001bd's. like i said.. im just curious, im not saying im going to do this but i might if i could get everything figured out.
what are your max dimensions ?
R.I.P!
(Nov-29-2009)
92 explorer
current build
and to wire it up you would need one big amp thats 1 ohm stable
Dual-4 Ohm Subwoofers: 1.3 Ohms
R.I.P!
(Nov-29-2009)
92 explorer
current build
I don't see them needing more than 2 cu ft each, so roughly 16 cu ft and you are willing to go above the window line with a wall....they should fit.
^^^A little confusion 6 or 8 subs?
Ya know....if I can fit 8 subs in a PT, Tahoe = no problem!
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
  • Who's Online   0 Members, 0 Anonymous, 4602 Guests (See full list)
