Mechman Alternators
Adjustable Regulator Option
Wiring them up is pretty simple too, only 3 wires.
But looks like mechman covers that too. :)
This is the way they you are told to wire them,
12+ terminal to battery
field terminal to smaller stud on the externally regulated alternator.
ground terminal to battery ground or alternator ground(preferd).
Posted Image
One thing that I was not sure off, but I figured since there was no ignition source for the voltage regulator and got connected to a constant 12volt source I assumed the thing never turned off. Unless it shuts off automatically????
I did a simple fix to this and ran a relay on a 12 volt ignition wire from my fuse box under the hood, and wired it for the relay to turn it on from the battery, and not the ignition itself becuase for some reason every ignition wire caused the voltage to be random from 13 volts - to whatever voltage I had the knob set at, and the relay fixed this.
  • 3 weeks later...
Ford Alternators can now be ordered to charge at 15V or 18.5V right out of the box for only $25 MORE!!! If you need a voltage bump for most Ford applications, give us a holler and we can build your unit with voltage boost for only $25. (some applications do not apply) This means that affordable 16V setups are now available ready to rock for Ford owners!!
  • Who's Online   1 Member, 0 Anonymous, 1621 Guests (See full list)
