tibs Posted February 6, 2009 Report Posted February 6, 2009 i just did the big 3 in my 99 f150. i went from the alternator directly to the battery. no problems with it, just wondering why dont they do that stock? and where does the stock wires go to? i goes to maybe a starter relay or something and also there is a fuseable link? Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
jlgn_2000 Posted February 6, 2009 Report Posted February 6, 2009 i just did the big 3 in my 99 f150.i went from the alternator directly to the battery. no problems with it, just wondering why dont they do that stock? and where does the stock wires go to? i goes to maybe a starter relay or something and also there is a fuseable link? Stock wire does ultimately get to the battery, I guess its not cost effective for the automakers to put a separate wire to connect directly to the battery. Make sure you use a fuse in your new wire. 94 3000gt 18" Kicker Solo X KX2500.1 2 KX350.4 8 JBL Coax Speakers 250A Mechman Alt
dmanson Posted February 6, 2009 Report Posted February 6, 2009 well your car uses the minimum gauge for it's electrical. once you start adding all that stereo stuff, then you go over the car's standard wire. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
tibs Posted February 6, 2009 Author Report Posted February 6, 2009 well your car uses the minimum gauge for it's electrical. once you start adding all that stereo stuff, then you go over the car's standard wire. i did. i just added on my wire.. i was just wondering why they went the way they did. Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
