Melissa Posted August 22, 2009 Report Posted August 22, 2009 I would like to get 2 18's on 10,000 watts if thats not possible than maybe 8,000. since t3 rates there woofers way below what they can handle I was thinking it might be able to handle 4,000 since the RMS is 2500-3000 and that was before he changed design. my new goal is also to play songs close to full tilt without getting low so maybe I need to be as close if not a little lower than RMS to achieve that. and john that could be a good possibility but I would really like to run something new see what else is out there. I still have not heard a LVL 5 18 besides outside of nymans hoe. seems like my BL likes being inverted. it can get down to 29hz now so if anyone has any suggestions for 2 powerful low hungry 18's powered by 2 4,000ish watt amps I'm up for it. You let me know when you want to hear a pair of LVL 5 18's
thehoe92 Posted August 22, 2009 Author Report Posted August 22, 2009 5.25 in pillars where were you tonight?lol and that also means I have to shove 6.5's in a 5.25" stock hole so do u think its worth it to turn the ssf off? my friend has a 1000bd and he never plays below his tune freq of 29hz, im wondering if this will help the lows I don't want to sound like I know everything and what is the best for his situation but in mine it was the best thing I did.the RF amps limit you a lot because their SSF is set to 28hz with a 12db slope so its not only cutting off below 28hz but it starts cutting into low 30's as well. its a lot of restriction and trust me you want lows You let me know when you want to hear a pair of LVL 5 18's yours would be another example Bill brought it when 99vic got his DAT amp and I heard it from the outside haha Wouldnt be thehoe92 without teh purple
thehoe92 Posted August 23, 2009 Author Report Posted August 23, 2009 been using my SecondSkin for a lot of miscellaneous rattles in my car and it works great! came with the folding knife and roller to the right and left of the rear window on tahoes and suburbans are air vents covered by air vent caps. this is where the air can escape from the cabin but it also lets SPL out. so I took the vent cap off and took the vent out to expose the leak covered it up with the SecondSkin and now when you shut the doors with the windows rolled up and you are inside you can feel slight pressure on your ears because the air doesn't escape. and finally my worst rattle is both the back plastic on the hatch and the trim around the rear window. both flex and buzz at higher frequencies. :ph34r: Wouldnt be thehoe92 without teh purple
98crewcab Posted August 23, 2009 Report Posted August 23, 2009 been using my SecondSkin for a lot of miscellaneous rattles in my car and it works great! came with the folding knife and roller to the right and left of the rear window on tahoes and suburbans are air vents covered by air vent caps. this is where the air can escape from the cabin but it also lets SPL out. so I took the vent cap off and took the vent out to expose the leak covered it up with the SecondSkin and now when you shut the doors with the windows rolled up and you are inside you can feel slight pressure on your ears because the air doesn't escape. and finally my worst rattle is both the back plastic on the hatch and the trim around the rear window. both flex and buzz at higher frequencies. :ph34r: lol wife didnt get home till 11:30, by the time she got settled, was too late to leave. I would've pulled in around 12, so thought...oh well, next time- and as far as fitting 6.5's in 5.25 holes.....cut dat chit and WHAT THE HELL IS THAT BOX FOR? no ninja chit, tell me tell me tell me! adding another 18? 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
thehoe92 Posted August 23, 2009 Author Report Posted August 23, 2009 I'm going to start on some mounting and placement tomorrow so I'll see if I can get by with the motor fitting in and just making a template for it. my other option is 6.5's in the a-pillars which would like sick but huge at the same time another 18 is in the process I just need to get my current system sold so I can get movin on it. I'll take some better pictures of the box tomorrow thanks again Elvis Wouldnt be thehoe92 without teh purple
98crewcab Posted August 23, 2009 Report Posted August 23, 2009 I keep holding 6.5's up to my pillars........just cant do it. thinking 5.25's would almost be pushing it for me. How bout you do it....first, then if i like....lol pretty sure it will be sick no matter what 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
thehoe92 Posted August 23, 2009 Author Report Posted August 23, 2009 well I have to do either of them because there is no way I am going to be fitting a t3 tweeter in the stock location on the a-pillar without the plastic bulging. I'm glad I got these though because I wanted something sexy lookin to go in the a-pillars and now I have them. carbon fiber and chrome FTW! Wouldnt be thehoe92 without teh purple
98crewcab Posted August 23, 2009 Report Posted August 23, 2009 well I have to do either of them because there is no way I am going to be fitting a t3 tweeter in the stock location on the a-pillar without the plastic bulging. I'm glad I got these though because I wanted something sexy lookin to go in the a-pillars and now I have them. carbon fiber and chrome FTW! And they are definately nice to look at 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
thehoe92 Posted August 23, 2009 Author Report Posted August 23, 2009 and my list from page 1... Sound System -2 18" Subs -Highs -Mids -Amps Exterior -Roll Pan -Tail Lights/Head Lights (Blacked Out?) -Mirrors (painted) -Door Handles (painted) -Side Molding/Emblems (removed?) -Chevrolet Emblem (painted) -Vent Cap (Escalade body color) -24” Boss Rims -Street Scenes Speed Grill Interior -Seats (black leather/fog suede Katzkin) -Suede Doors -Tinting (5% back 5 all windows) -LED’s (purple?) -Sound Deadening (72 square feet) Engine -300 Amp DB Linc Alternator -Big 3 Wouldnt be thehoe92 without teh purple
donsie Posted August 23, 2009 Report Posted August 23, 2009 You got 5% all the way around? Or just the rear windows? chicken is basically the native american hulk, you think he broke that curb with his rim? think again, that was merely him stubbing his toe.
