Please Help I Cant Stand It...
aight so i was coming t the end of an build and got stumped on my amps...i cranked my truck to hear my new sytem but my highs whined so horribly louder than ever... and when i turned my volume on the radio from 0 to 1 it made a loud thump and my subs tremble as i would call i... i replaced the ground put diff grounds for each of my amps and diff power wires and still whining and tremble...so a friend told me to try gettin a better ground on the radio....sitill the same whining and thumping... i tried new rcas still the same i dont know what the hell it could b...Please help
1996 chevrolet s-10 ext cab truck
18" chrome rims
4" drop
smoked tailights
custom 2 tone white n black interior
7" visor flip downs
7" flip up cd/dvd
pioneer door speakers all the way around
k-9 unit alarm
horns underneath(hearin me coming and leavin...clearly)
green neon Street glow
coming soon
4 12" kicker cvr's 300 4 all
2 1000 watt autotek mm amps 200 per
apc steering wheel 100
hid headlights 175
grille 99
roll pan 89.99
2 tone outside paint job black/ white ?
22" mezzano rims 2,000
i have a noise supressor but not quite sure how to hook it up... theres a red wire a black and blue red for power blue for remote and black for ground but my amp stays on when i hook it up like that so iidf that would make it stop whining then i would need to know how to hook it up correctly ...got any ideas???
18" chrome rims
4" drop
smoked tailights
7" visor flip downs
7" flip up cd/dvd
k-9 unit alarm
coming soon
hid headlights 175
grille 99
roll pan 89.99
if its a pioneer headunit then you have the notorious rca ground problem. wrap some wire a couple times around the rcas. soulder it if you want but be careful or just tape it and then ground those wires somewhere. every pioneer i've ever messed with has been like that.
Try running a ground to the ouside tabs of your rca's its a pioneer therye known for whining.
x2
Grounding the RCAs will most likely solve your problem. An easy way to test would be to leave it all hooked up and just touch a wire from the RCA preout junction to a good ground and see if it stops.
One grounded RCA should solve the problem for all the preouts on most units.
Need an install? Hit me up.
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 2516 Guests (See full list)
