what the stuff Steve used on Chickens towers..(im too lazy to check now)
that looked real good and that would look good on that box too.
thats bedliner
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
do terminals make a difference
Terminals give a clean look, and a pretty easy way to connect and disconnect, but unfortunately they usually represent a weak point in the box.  Seeing as the whole box is 3/4" wood, and then some thin plastic, its normally a flex point in higher powered enclosures. Bolts are generally stronger.
Sorry, back to the thread.  :hj:
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Well,
This is prolly OLD NEWS for any of the OG's, But I'll drop this lil tip here as it seems less-well-known than I'd thought:
When using Terminal cups or premade wire hookups on a box, If it HAS to be a "panel" or "cup" which are "nice and clean looking", NEVER TRUST PREFAB PARTS. They are made QUICKLY and CHEAPLY in MASS. We all know them to be much weaker (and thus the most likely place for a leak/breakage) than MDF or fiberglass...so...
Take a look at what Steve did on the towers and LOOK CLOSE at the terminals.
Steve didn't just slap some Terminals in and call it a day, he rhino-lined over the top of them to give them: 1. a better finish, 2.a better SEAL, & 3. a lil more strength.
I have gone as far as coating the inside of the thin plastic terminals w/ resin or resin/bondo milkshake to ensure they are strong enough for the pressure of the box.
As long as you leave the connections in place and cover over them it will only serve to make the CONNECTION stronger too and less likely to SHAKE LOOSE inside the box.
Laying a layer of actuall glass aint gonna hrt either esp. if you cut a lil hole for ur wires and just glass around them (that is only necc. if you wanna keep the terminals "removable" or disconnectable w/ cutting the wires).
The other option is to mount the terminal normally and make a 2nd baffle inside the box as a "2nd interior wall" essentially doubling the thickness where the terminal is and on that 2nd/inside baffle ONLY drill big enough holes for your wires to pass thru & them silcone/liquid nails them up nice and airtight.It will look normal on the outside but be airtight and strong inside.
If there's "pressure" inside the box pushing out, the less surface area that pressure has to push on the less likely the box will suffer a structural failure of leak (meaning make your "weak spots" smaller...or stronger).
Any help there?
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
or yea u could glass the outside too and paint it with automotive paint just like ur car....now that would be hot. Especially if u had a overlay vanity panel to go on top of it so ur amps would be flush
00114-1.jpgTEAM MechMan Alternators
wow...thanks guys...i think im going to rhino line it...anyone know about how much it would be??
id fiberglass the inside too, but i wouldnt have any clue as where to start :(
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
