speaker wire gauge is over rated
nothing wrong at all with doubling up 14g, but if you are maxing the woofer, running 1ohm, stuff like that, its a little more important to go up a size or 2 or 3
One think I learned in electronics is, with AC size isn't THAT big of a deal, as compared to DC
If it did matter, why wouldn't an amp that takes 4 gauge in, have 4 gauge out?
Since its AC, and it alternates, the wire doesn't get warm as if it were a DC out on the amp
Why else is a 220v dryer that draws 30 amps only use 10- 12 gauge on there power cords? because its AC- and that is at about 6,600watts of use at peak, probably more realistic at 2000-3000 watts continuous
Another example is the power lines that go from power stations to your home. In the air they are what, 120,000v AC? and that is only like equivelant to a 4/0 g wire
But I assume people use small gauge power wire to keep electrical resistance as close to the coils resisitance as possible
DVC 4ohm coil actually read close to 4ohm at the amp, than 5ohms
Edited by Forevrbumpn
2 runs of 14 ga is fine.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
THE MAN HAS SPOKING
Check his stats if you don't know!!!
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
foreverbumpin, voltage doesnt mean anything, you can run 200k volts through 22g, the amperage is what matters
running 30amps peak through 10g, not so impressive, even if it does come out to 6000watts, its only 30 amps, and thats what the wire carries, the amperage.
that being said, you're fine dooubling up 14g for the subs, but doing a single run of 8 is probably a better bet.
Team DC
i unno why but how come i cant search for this company on the net? my local shop sells this stuff its called, mobile engineering inc. hyper stream 8gauge 2conductor speaker wire, its like $3ft tho but is tight as hell and cleans up space alot, i love this shit tho i wonder if anyone can find a website that sells it cheaper, i think its the only 8guage speakerwire ive seen, not like runnin 8guage single conductors this has 2 in the same caseing just like 10guage speakerwire n so on, looks like other companys would do this or is it cheaper to buy 8guage single conductor wire vs 8guage dual conductor speakerwire?
edit: it has some japaneese shit wrote on it also, but anyways most ppl run 12awg to subs so i unno why dual 14awg will hurt it, just as long as its not single 14awg, i dont think ur amp will like it lol
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
THANK YOU SIR.
was wondering why all the people are talking about wire size....
just need to know if there are penalties on the signal if using 2 runs of a speaker wire.
Regarding two runs of wire to a sub, perfectly fine and wont affect quality. Especially not at the frequencies we're talking about for bass, hell a stick covered in aluminum foil would probably work. :)
Secondly, strand count is a very poor method for comparing a wire's current carrying capacity, since again, at the frequencies we're dealing with power conducts THROUGH the conductor not on the outer skin as is the case for HF. Not to mention the size of the strand is NOT defined in either circumstance, it's a guess at best. So the proper way to compare the ampacity of two cables is to look at the conductors cross sectional area, in circular mils or kcmils.
A 14g conductor is 4106 cmils.
Two 14g conductors in parallel is 8212 cmils.
An 8g conductor is 16507 cmils. To equal the same current carrying capacity in a 14g cable you would need 4 parallel conductors.
Two 14g conductors is between a 12g and 10g conductor, perfectly fine for most subwoofer wiring tasks.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
