Everything you put in line with something helps build up restince(can't spell).
I also feel its safer.
true
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
I too also think the use of bolts is (not a bad idea) but not a good one to use in HIGH power applications. Everybody chime in bla bla bla, but like Jon said each place you teminate is going to add resistance.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
even with big fat stainless bolts?
Yup
well then, I guess I'm gonna run garden hose through...lol
I had 2 runs of 8 going thru the back of the bubs enclosure per sub so I think youll be fine especially if its ported (but some sealant over that area will help also.
Scientia est Vox
yeah, definately ported, possibly a t-line, most likely regular ported til I get my second amp and sub :diablo:
i used the bolts myself but i pull my stuff out alot to try diffence setup. but if thats not the case then go with what roscoe said.
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
As far as the impedance read from solid wire vs. wire/bolt setup I saw no difference on my meter. I tested both because I was having the same concerns, but if anything the rise is negligible.
I guess with very high power applications it would matter, but for a daily driver it's nothing to worry about.
Need an install? Hit me up.
[email protected]
yeah, I don't see myself changing alot, so straight through it is :)
thnx guys ;)
  • Who's Online   0 Members, 0 Anonymous, 692 Guests (See full list)
