if im doing a box like this: 9cubes1181272porttunedto33hz.jpg
would i need some sort of bracing? i dont really plan on doing any resin
how thick mdf are u using? and what program did u use to design that?
My First Set-Up (2008)
-Kicker CVR 2 ohm 12's in crap Prefab box
-Rockford digital 1 farad capacitor
-Hifonics Bxi1608d
-DB Link 2 gauge wiring kit
-Pioneer DEH-P3000IB Head Unit
My New Set-Up (2010)
-4 Alpine Type E 10's
-2 Apline MRP-M450's
-Custom box tuned @ 36 hertz
-JVC KD-R310 Head Unit
-Rockford Fosgate 4 Gauge wiring
-Monster Cable RCA's
On the poor mans budget
this is what i would do with 1" dowel rods
are you using allthread or dowel rods
if dowel rods, i made them intersect as much as possible since it makes the whole box stronger if ur not gonna use resin
edit* id love a birds eye view, would help to see if vertical supports can span bottom to top since it looks like the box is port up sub up in a suv maybe?
Edited by decafcappucino
if i would it would most likely be the threaded metal rods
birds eye/top view..?
umm still would work just lower... and if ur using allthread you might as well run the pieces all the way thru each panel since you cant really tie the allthread together, each rod is only as strong as it by itself
if your flush mounting the sub, might want to add another baffle so there is at least two baffles for the screws/tnuts to bite into/and support
what sub
what sub
it would be doubled on top, flush mounted. it would sit port up sub up in my car. sub is dc lvl 4 xl.
Edited by takenotes101
I would do 1 1/2" dowels instead of 1". I use that in my boxes and will have pics up very shortly of a new box build for a pair of 15's using the 1 1/2" oak dowel.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
  • Who's Online   0 Members, 0 Anonymous, 1117 Guests (See full list)
