2 amps 1 sub
babyjoker
I have 2 Kicker KX400.1's and i was wondering if i could wire them both to one sub(not DVC).What would happen, would it damage the amps,the sub or just not work.Not planning on doing it, just curious.
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
its a single voice coil so how would you go about wiring it to the sub. you need to wire BOTH pos and negative and you cant do 1 pos of 1 amp and 1 neg of the other amp. and i wouldnt recommend wiring 2 amps to 1 coil. Unless you sync the amps which i dont think that amp is capable of. If it was DVC i would see you wiring 1 amp per coil. If you need more power then sell what you have and get something more powerful.
NoFearX18 said:
trainman0978 said:
after a lil research i found that you can strap those 2 amps together and wire it to a final load of 4 ohm.
NoFearX18 said:
trainman0978 said:
yeah i know that if was DVC then it wouldnt be a problem, i was just curious if it could be done, and how would i strap em, i know that 2 amps can be connected with a cable or something and one would be a master and the other a slave,right? i checked the amps and they dont have anything other than rca inputs, and the speaker outputs.
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
thats weird...i did some looking up and it said that amp can be synced. i dunno where on the amp that will be but not fully sure...Kicker isnt my brand that i know a lot about.
NoFearX18 said:
trainman0978 said:
just dont do it...
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
