dr hypothesis Posted February 20, 2009 Report Posted February 20, 2009 Although I've been building boxes and installing for 8 or 9 years now, I've actually never soldered. Had a friend who I did a lot of installs with that would usually do it. Not sure why I never learned from him. Anyways, I checked out the stickied topics here and they helped quite a bit. I more or less used the method Steve showed. Heating the top part of the ring, got a good puddle going, then heated the bottom part of the ring so the solder sucked down into the wire. Enough that a little bit dripped out the bottom. Then put another puddle on top and tried to get it to flatten out. Edit: N/M on the question I had. It seems these came out pretty solid for me. Guess I shall see when I actually get to run my wiring. 2001 Chevy Impala Eclipse CD7200 mkii Cactus Sounds 5kw Sundown 100.4 (2) Fi BTL 18s (walled) ID 6.5s (2 sets) Iraggi 320 amp Alt XS Power Batts KnuKonceptz Wiring MidwestSPL Scores: 152.0 Advanced 2 136.1 Extreme 3
bobonit Posted February 21, 2009 Report Posted February 21, 2009 Yep, that looks soldered on pretty good. 97 Maxima SE Bunch of shit going in, check out the build Build Log
dr hypothesis Posted February 23, 2009 Author Report Posted February 23, 2009 Steve's instructional post and kentb's vid defintely helped out a lot. This was something I should of been doing a long time ago! 2001 Chevy Impala Eclipse CD7200 mkii Cactus Sounds 5kw Sundown 100.4 (2) Fi BTL 18s (walled) ID 6.5s (2 sets) Iraggi 320 amp Alt XS Power Batts KnuKonceptz Wiring MidwestSPL Scores: 152.0 Advanced 2 136.1 Extreme 3
troy Posted February 24, 2009 Report Posted February 24, 2009 do you use flux or anything retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
dr hypothesis Posted February 24, 2009 Author Report Posted February 24, 2009 No, I didn't use any flux. Just 60/40 rosin core solder with a good ole propane torch. 2001 Chevy Impala Eclipse CD7200 mkii Cactus Sounds 5kw Sundown 100.4 (2) Fi BTL 18s (walled) ID 6.5s (2 sets) Iraggi 320 amp Alt XS Power Batts KnuKonceptz Wiring MidwestSPL Scores: 152.0 Advanced 2 136.1 Extreme 3
