Torres' Box Tuning Calculator - Updated 8/18
Torres
EDIT: just been tweaking some small things here and there. mostly things that were pointed out to me (thanks :drinks:) most recent version is posted up on 4/28
FIIIIIINALLY!!!! finally freakin done with this update. only took 4 months lol. got a whole new slew of things. here's a screen shot of what it looks like
sorry for such the large size. it was hard squeezing so much into such a small box. i do realize that on some resolutions the program wont display fully on the screen. but maximizing will fix that until i can figure a better layout or a way to fix it. it should have pretty much any suggestion that was thrown my way that i could find useful. along with a couple last minute changes, like the desired net/gross volume boxes
here's the download link to the program:
Box Tuning Calculator Download
***you'll need the most up to date .net framwork for this program to work. click this link to get it***
.NET Framework
there's port cut sheets in there, but one thing i did NOT include are cut sheets on how to cut the port if it bends. there's too many different ways to cut the sheets, and the coding to go into that would be too tedious to deal with. maybe at another time down the road. right now i want to get it uploaded and not have something silly holding it back. plus, if you're building a speaker box, i'm sure you can go take some measurements in the box and see what the port should be :)
i've also included a FAQ/tip sheet with it this time around. so if you get confused with something, click there first. if you're STILL confused, send me a PM with any questions. with that being said, i'm still going to paste all the contents of the FAQ here.
Box Frequency Tuning Calculator - FAQ/Tip Guide
1 - First and foremost, the RE calculator is *not* spot on, and is limited in design, so no, it will not match this calculator.
2 - When doing an oddly shaped box such as a fiberglass box, or you know the volume of a certain box you have in mind
that you want to build, put the net volume in the 'Desired Net Volume' box. This will bypass all dimensions entered
preventing you from having to guess dimensions to get a certain net volume and will allow you to tinker with different
port sizes and tuning. So if you know you want a box with 4 cubic feet of net volume, enter '4' into that box and it
will allow you to adjust tuning accordingly to that specific volume. Keep in mind that any displacement nor port volume
is NOT subtracted from this total.
3 - The 'Desired Gross Volume' box acts much like the Desired Net Volume box, except all displacements are taken into
effect.
4 - If the number of aero ports is greater than 0, then that automatically gets taken into effect and the calculator ignores
the dimensions for slot ports.
5 - The '# of Common Port Walls' box refers to how many sides of the box are going to act as sides of the port.
6 - Port length uses the box wall or baffle(s) as part of the port length. So a port that is 10" long with one baffle using .75"
wood will only need to be 9.25" long as the box wall or baffle(s) will account for the other .75". If using two baffles,
then it would be 8.5" long as the baffle will account for 1.5" of port length.
7 - Port walls are defaulted with a .75" thickness.
8 - Regular square/rectangle boxes do not need any numbers entered into the 'Height 2' or 'Depth 2' boxes.
9 - Pressing 'Enter' will prompt the program to print.
10 - Slot port area range is based on 12-16 square inches of port per cubic foot, while aero ports are based on 9-13 square
inches per cubic foot.
10 - On the cut sheets of boxes with different depths and heights, you'll notice 'H1' or 'D2' next to the measurements.
These represent which dimension is which. Here are two pictures to illustrate:
Box with one height, but two different depths: http://img59.imageshack.us/img59/8449/angledcutsheet1.png
Box with two heights and two different depths: http://img163.imageshack.us/img163/607/angledcutsheet2.png
If they do not go in the proper order, the sheet will not come out properly.
--Here is the formula the calculator uses (the same on displayed in the program itself):
http://img713.imageshack.us/img713/2590/tuningformula.jpg
--The following are links that illustrate how each ported box is taken into effect in the calculator (sub and port position can be upwards with the same effect):
1 - Port with 0 common walls: http://img693.imageshack.us/img693/6474/independentport.jpg
2 - Slot port with 1 common wall: http://img341.imageshack.us/img341/9939/bottomportbox.jpg
3 - Slot port with 2 common walls: http://img94.imageshack.us/img94/2017/middleportbox.jpg
4 - Slot port with 3 common walls: http://img246.yfrog.com/img246/6968/slotportbox.jpg
--The images were made with Google Sketchup. Free to use: http://sketchup.google.com/
should be 99% debugged (i think). but after staring at the same coding for so long, things are bound to slip by. so IF you do find something that seems out of place, PM me about it please. and only if you're certain about it. i dont want to go check something or explain how it's done several times over because it may be coded a certain way that you may be thinking differently. that'd be too tedious for me to do constantly.
hope you guys like it :)
This thing is absolutely amazing but I can't get it to work on my Macbook!!! This might have been said before but I havent been though every page!!! Help me out dude
****01 Chevy Tahoe****
Fabtech 8" Lift W/ Toyo M/T's 37x13.50
20" KMC Monster Wheels
DDM Tuning 10K H.I.D's
2 Kicker CVX 15's
Hifonics Brutus BXi1610D
Optima Yellow Top
Big 3/Stinger 0 Gauge
It's a windows form application. If there's a way to get it to work on macs, I'm not aware of how :( sorry. Someone else may be able to chime in tho if there's a program that can run along side of it that will allow it to work
Parallels, VMWare Fusion, VirtualBox... You might also be able to get it to work with Wine, but considering you asked the question Wine might be a little over your head (no offense).
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
No offense talking dude! But which would be the best program to download in order to run it?
2 Kicker CVX 15's
Optima Yellow Top
and you'd notice in the first post that i pasted the help window in, and the first line in the help window in the program it says that the RE calc is not 100% accurate so mine will not be the same as theirs ;)
and thanks underlok :) i think i heard of a way to do it before but i forgot how
in your calc where you put port length say it says 20" then in the side box it says actual port length is 16". Which one would be the actual wood length.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
i wasn't shitting on your calculator; i was just informing you of the difference; i just like how they show the design
Eye Kandy Kustomz
2414 E. Napoleon St.
Sulphur, LA 70663
(337)313-3121
[email protected]
Eye Kandy Kustomz Page
My Page
you're good i wasnt saying you were. people compare the two calculators together a lot and always question me about it lol. no worries. i'd like to get to a point where i could display the different types of enclosures according to how the user enters in the information, but that may be a ways away lol.
and loburbon, the 'physical port length' box is what the actual wood length should be. in your case, your port is about 4" wide, right? and it bends, so the physical port length gets a little shorter as the bend accounts for the 'missing' length.
  • Who's Online   0 Members, 0 Anonymous, 1309 Guests (See full list)
