devsmazduh Posted February 22, 2009 Report Posted February 22, 2009 would this design work? i dont have all the measurements yet. butim just asking if the basic design would be good? thanks in advance Quote ill cut out yo eyelids and give ya nothin but sleeping pills...
loganberry Posted February 22, 2009 Report Posted February 22, 2009 i think you would have to bring the port in the middle down some, and remember your tuning will be a lot lower than what you tune your box to Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
devsmazduh Posted February 22, 2009 Author Report Posted February 22, 2009 ok. could i go without doing the middle port? im just thinkin, cuz i figured i should put it there so it would focus the pressure into the cab. but i guess if its seald up enough then it would anyways right? Quote ill cut out yo eyelids and give ya nothin but sleeping pills...
loganberry Posted February 22, 2009 Report Posted February 22, 2009 you dont have to put it there i dont think, but somehow make a short one work just to see? the hard thing tho is the air has to travel down the tunnel then when it enters the cab its gonna be low low, chode had the same problem and could only play super low songs....so make sure you tune your box high at the port so you have a better chance for decent tuning in the cab Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
mike fallon Posted February 22, 2009 Report Posted February 22, 2009 I would run the ports at the top firing into the cab, ala hoopty ports Quote
RamenNoodles Posted February 22, 2009 Report Posted February 22, 2009 Do it like this. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
loganberry Posted February 22, 2009 Report Posted February 22, 2009 the squigly's (sp) add dbz!! Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
RamenNoodles Posted February 22, 2009 Report Posted February 22, 2009 FRICK YES! helps sound waves get more squiggly which obviously means more deebeeezzz Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
devsmazduh Posted February 22, 2009 Author Report Posted February 22, 2009 lmao! hahahhahaha. im gonna try it with the ports closest to the cab. Quote ill cut out yo eyelids and give ya nothin but sleeping pills...
loganberry Posted February 22, 2009 Report Posted February 22, 2009 lmao! hahahhahaha.im gonna try it with the ports closest to the cab. that will be best way in all honest, i say move the subs back towards the back, and port it right at the front so you have less tuning drop and its a lil easier to work with, id way tune to high 30's and end up with a lowish 30's final tune, depends on your subs tho Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
