those ports would work. you could even use large PVC pipe if the diameter is the same. but dont be too disappointed if the output isnt what you expect. ported boxes tend to be a lil larger before port displacement and everything
No i too 1 1/2 inches off it to compensate for the 3/4" on each side so its internal measurements, i like low bass but thats all it can really move air with is that really low bass like in the high 20 to 30hz range. but im gonna try to block off part of the box first and see how that sounds then if all else fails ill try the port cuz im not to worried about the box cuz its only gotta last till the taxes come back lol then im throwin another 12w7 in it and having a good friend of mine build me a 3.5ft3 ported box with a common chamber tuned to around 35hz so ill give yalls ideas a shot thanks for the help, noobs can always use it. :D
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
ok just checkin. sometimes lil details are easy to look over and can make a big difference ;)
Hey so i used your box tuning calculator and i think i came up with a decent set up that will tune it to about 35 hz with a 4x10 aeroport im just curious as to whether you think that will be to low for what i have or if it will help a little at cuz it only cutting my box down to 2.2ft3 but reccomended is 1.75ft3 tuned at 41 hz any input would be appreciated. sorry for all the questions, im a hardcore noob but i really wanna learn. :sorry:
1 Dc lvl5 18
shootin for 145+ :)
i'm not sure if that's enough surface are for that much airspace. i say just give it a whirl. you could be happy with it...and you might not. big part of learning is doing things ;)
