i really like that u wanna throw an IA Dp 21 in there. that sub is badass
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
yarp.
I was gonna run (2) DC LV4XLs w/ (2) AQ 2200ds...
But this setup will save me $1k almost & it'll definitely get that 'wow' factor when people see it.
My esitmated price total in audio right now is ~$1700
your budget is very low that sub is not very cheap, you need to consider, enclosure, wiring, and proper electrical, that car has alot of electronics so it may have a large alternator, but also uses more of the alternators juice, just something to think about.
DCAUDIO
BALLS DEEP
nice ride man. beats out my bmw as a first car.
mr.p is rite tho, my car had alot of electronics so a big standard alt already, but not enough so i had to upgrade. idk wat ur stock alt puts out but u mite wanna upgrade to power that AQ. or atleast more batts
i also like the interior btw
Ride: 2001 BMW325ci
Headunit: Alpine ida-x305
High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total
Sub: (1) 15" DC Audio Level 5 D2 ohm
Amp for sub: MTX 4001d
Box: custom built 3.5 cuft ported
Power: 220amp alt from ohio gen, 2 kinetik 2400s in back
(Armoredhaulin @ May 29 2009, 08:34 AM)
Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
that's why you don't go to dealers and instead go to individual shops. Usually have more experience b/c they once worked for a LR dealer & got fed up with the shit.
But really, after reading a WHOLE LOT these are fairly reliable besides normal wear and tear. Only 2 major faults are so:
1) The Three Amigos: Your ABS system malfunctions & you lose HDC, ABS, & TC but brakes still work completely fine.
2) Head gasket leaks. That's about ~$2000 to fix. But once at around 100k & you won't worry about it again. It's really only like $300 for parts but then a SHIT LOAD of man hours to replace them.
taking the top half of the engine out :fool: :fool:
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Well I have figured out the cost pretty well actually. Here is my list:
(1) IA 21" Death Penalty--------------$653
(1) AQ 2200D ---------------------------$389
(1) Deka 9A31---------------------------$200
(1) Homemade box~~~~~~~~~~~ $150
All Wiring~~~~~~~~~~~~~~~~~~- $300
TOTAL------------------------------------------------$1692
I'm going to monitor my electrical as it is above. If that doesn't cut it, another Deka 9A31 is going under the hood. I already measured, and it fits with room to spare. :) If that upgrade doesn't cut it, then add another $450 on for a 240A alt.
yarp
