Looking good man
thanx bro
don't know if i should upgrade the alt
01 Tahoe
Big 3
20 ft.1/0 streetwire under hood
4 Batteries
Stock Battery and
1800 Kinetic Batt under hood
2 Sprinter S12V500F Battery,165 AH
Kicker 1/0 going from front to back
Sirius sportster
Alpine 9886
Kicker 650.4zx mids and highs
Q-Logic kick panels w/Kicker6 1/2 comps.
XXX re comp 6.5 in front doors
Alpine6.5 coax in rear doors
2 Audioque 2200d strapped
2 Audioque 18 HDC3
5% all the way around
2 layers raamat on roof
doors covered in raamat
Im thinkn bout getn an alt for my hoe. I just ordered my first real system. Im just waiting on my subs and components
"Da 2tone HOE from the 520"
Or can you have them down and not really worry about over heating and stuff on those lines.
Theres also about 10 inches from the bottom of the seats to the floor where the amps at. Maybe a lil bit more, and its very open space.
although the expedition is slightly bigger than the tahoe, i have always loved how the tahoe's 2nd row is. you can just slide an amp or two under them and they will still have good ventilation.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
how you like them xxx components?
they sound decent would prob go with something different if $ was right but times are rough
i NEED to dynamat or something on the doors would probably sound a lot better
the whole ride need a couple of layer
01 Tahoe
Big 3
4 Batteries
Stock Battery and
Sirius sportster
Alpine 9886
2 Audioque 18 HDC3
would it be worth it to add an alt?
or do you think i'm good
how would i check to see how many volts i'm holding at?
01 Tahoe
Big 3
4 Batteries
Stock Battery and
Sirius sportster
Alpine 9886
2 Audioque 18 HDC3
adding and alt just let's your electrical run smoother. you can check your voltage with a dmm or voltmeter.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
