i doubt it man.
i honestly think port noise is a myth cause ive built boxes with only 1" of port width with 0 noise.
IVE NEVER had port noise.
meh i had a 12 with about the same port width and and same size box and it made some nasty port noise. OP you may be fine vut im going off my expierence
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
you can use a slightly bigger screw, or throw some electrical tape over the other hole ..... id just leave it there being as its gonna be under the carpet and never seen anyway ...
will like snow or rain coming up from the street get into it and start rusting? cuz if not ill just put tape over it and call it a day.
I am now kind of nervous, and hopefully it works ok
ive never had that problem but i dont live in snow.
throw some tape over it .... id do Duct Tape though instead of electrical tape personally.
EDIT: Dont be nervous, if it has port noise just take the box and re do the port a bit bigger and shorter/longer for your desired tuning frequency.
2nd Ninja Edit: Or just rebuild the thing.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
cool then thats what ill do then, and just to make sure i can ground the battery and then just ground the amp to the battery right?
problem with rebuilding box is that my dad cut the wood at his work, cuz he wont let me use his table saw outside when its so cold. but he cant cut any more wood there :/
grab yourself a skill saw.
i didnt even use my first chain saw until i was 18 years old despite my dad being a construction worker/carpenter.
skill saw around 15 as well as a table saw.
im gonna recommend the Ryobi with the Dual laser guides. you can pick one up from Home Depot for around $70. grab some of the Husky saw horses as well. they are pretty decent and start building your tool collection ....
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Me and my dad used to have a father son buisness of woodworking, he did it as a hobby and hes got all the tools i need, but i bought all the "little essentials"
either way its good to have your own tools.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
agree with the port, looks a lil to long and skinny? did you use the port box calc? if so did you keep an eye out for your port ratio, and also your sq inch of port per cu ft of box. I really like to stay away from skinny ports... yea there is noise ive had some nastttyyy stuff. If it dose not sound the greatest redo the box with a wider port to get the ratio down and the sq in of port / cu ft of box to around 14. your tunning spot is perfect. i like it in the mid to low 30s.
other then that it looks good for your second install man. I know my first ones i would of never tried a ported box. i always went sealed.... but now i would never go back to sealed..
cliff
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
