I just put in two D1 FL 18" btls, powered by an SAZ3kD...I matched the gain to the HU with my DMM and even set it a little low just to be safe. Well the problem is that the sub on the left almost sounds as if it is bottoming out, and the other one is just fine. I set the gain back even more and it still does it. does any one have a suggestion on what could be causing this to happen? thanks...
'05 GMC Envoy
H/U: PIONEER AVH P4300DVD
Subs: (8) SA-12's
Amps: (2) SAZ3500d's
MECHMAN 270A Alt and 5 Batteries with lots of 1/0
check your wiring.
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
check your wiring.
i checked it and i have both subs wired to 1ohm and i used both sets of terminals on the amp...
'05 GMC Envoy
Subs: (8) SA-12's
hooray...
errr....
is each sub series wired than paralleled to the amp??
Edited by EricM9104
not to sure on those subs but i had the same prob with my dcs and its a problem with the motors i had to give them back to rusty for recones kinda sucked
must be nice huh
hooray...
errr....
in ran pos to neg on each sub individually
'05 GMC Envoy
Subs: (8) SA-12's
hooray...
errr....
no
'05 GMC Envoy
Subs: (8) SA-12's
how do you wire a dual 1 ohm sub to 1 ohm?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I wired them like this
'05 GMC Envoy
Subs: (8) SA-12's
