jizazz12 Posted March 4, 2009 Report Posted March 4, 2009 i am in the middle of a rebuild and am wondering if i should add a line driver to my set up. i will be running four amps off of a pioneer premier prs880 , the head unit has 5. volt pre outs but am wondering if i will loose any of this with the amount of amps I'm running .amps are 2 Jl 1000/1 , 1 Jl 450/4, and 1 Jl 300/4 . any suggestions or advice would be appreciated thanks. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
ISO Posted March 4, 2009 Report Posted March 4, 2009 If you use the pass throughs on the JL amps you shouldn't have a problem with signal loss. Its called daisy chaining amps and on most high end amps they should have a circuit in them to keep the signal consistent when RCA's from one amp go to another amp. I'll go to their website and check I'm bored anyway. If you want a line driver I recommend Phoenix Gold. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
jizazz12 Posted March 4, 2009 Author Report Posted March 4, 2009 thank's for your help. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
ISO Posted March 4, 2009 Report Posted March 4, 2009 Ya man I didn't find anything on their site to confirm what I said but with as much signal prosecing as they have on the outputs I wouldn't worry about any signal loss from the Slash amps. Infact reading over there made me want to buy one LOL. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
Decaf Posted March 4, 2009 Report Posted March 4, 2009 i am in the middle of a rebuild and am wondering if i should add a line driver to my set up. i will be running four amps off of a pioneer premier prs880 , the head unit has 5. volt pre outs but am wondering if i will loose any of this with the amount of amps I'm running .amps are 2 Jl 1000/1 , 1 Jl 450/4, and 1 Jl 300/4 . any suggestions or advice would be appreciated thanks. ur headunit has 3 outputs 2 fading for front and rear 1 non fading for subwoofer so use the front and rear preout rcas for the 4 channels and use the 1 sub preout to one amp, then run a 1meter or less rca using the passthrus on the 1st sub amp to 2nd amp no need for a line driver or anything crazy
jizazz12 Posted March 4, 2009 Author Report Posted March 4, 2009 i was hoping that i wouldn't need one ,not trying to cut corners but if i can use the funds on something that i really need i would rather do that. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
jizazz12 Posted March 4, 2009 Author Report Posted March 4, 2009 cool thanks for the info. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
