Can you just run 6 wires from the batt and make a switch on the dash?
You could, but it's not needed if you just connect a relay in to the remote path. If you connected a switch and forgot to turn it off, the amps would stay on until your battery dies.
"I don't bullshit. I do what I say & say what I mean."
http://www.cardomain.com/ride/2925230
http://www.armoredhaulin.com
or you could tap into the ignition switch so you wouldnt need a 6 wires or a switch on the dash
Quote
true but then if he turned off his radio the amps would still be on. not a big deal but im just saying.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
