I lowered my tahoe and threw some 24's on it. I just noticed left rear wheel is towing in a bit not serious but noticable. Anybody have any ideas on what could cause this, I was thinking wheel bearing, but not sure
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
jack it up and tighten the lugs, might be that but not sure
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
x2 on checking lugs, if it isn't those pull the rims off and check to see if your whole brake assembly is tilted or not.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
yeah, and after that while its still in the air see if you can shake the wheel...
The wheel has a little play in it in and out but not too much. Both back wheels do
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
its normal to move a tad bit...its just play in the c clips on the axles but alot of movement could be axle bearings
2001 chevy silverado 1500
h/u- pioneer avic-f900bt and custom molded 7 inch monitor in center console
mids/highs-memphis m-class 6.5 component set
subs-3 kicker L7 12's seprate chamber box at 43hz and aprox. 3 cu. ft.
amp- treo ssx 2000.1
all memphis 0 gauge wire and rca's
Plans- 2 treo ssp 18's
kinetik 2400 batt and a mla module and high amp alt
focal 6.5 components and amp
Well after really looking it just seems that my right rear is a little further out than the left, could it just be my rear end is tweeked to the right
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
That might be it, mine leans a little to on side too! I had somebody say that they thought my back wheels/wheel looked funny.
"loud 'cause its clipped like a 7yr olds buzz cut" -Decaf
"unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
that truck has a trac bar... have you got a 4 wheel alignment lately?
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
  • Who's Online   0 Members, 0 Anonymous, 1605 Guests (See full list)
