Denis22 Posted February 13, 2007 Report Share Posted February 13, 2007 Whats up. So i have a little system going on. Just got sub and sub amps installed the other day. For starters I upgraded my underhood wires, the big 3, all to 1/O wire. Upgraded alternator to 200A alt. from Natahn @ excessive amperage. Have 3 amps.. 2 Alpine MRD-M850's and a JL Audio 300/4. Clarion drz-9255 h/u. Sub = Re Audio 06 XXX, one Alpine/coil. Sub is dual 2 ohm version. Front stage = JL Audio zr5.25csi, i know overpriced but i bought them well over a year and a half or 2 years ago they sound great. 1/O wire running from batt. to trunk where the dist. blocks are. When i'm driving the lights still dim pretty badly. I was wondering if anyone had any further suggestions on what I should do? Thanks for the help, and im new to the forum also. Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted February 13, 2007 Report Share Posted February 13, 2007 how clean are your grounds? how many batteries? Quote Link to comment Share on other sites More sharing options...
Denis22 Posted February 13, 2007 Author Report Share Posted February 13, 2007 single 1/O ground from dist. block to chassis. used a wire brush to scrape it, all metal. bolted down. single battery, starter battery. Quote Link to comment Share on other sites More sharing options...
dleccord Posted February 13, 2007 Report Share Posted February 13, 2007 sand your grounds down to bare metal, use the biggest fuse for that wire you can afford, but check your gains and set it properly. that is not a lot of power really to be dimming. i assume all your power wires are 4 gauge to the amps? Quote refs: chode69, superduper Link to comment Share on other sites More sharing options...
Denis22 Posted February 13, 2007 Author Report Share Posted February 13, 2007 grounds are down to bare metal, i will check gains tomorrow. thanks Quote Link to comment Share on other sites More sharing options...
Denis22 Posted February 13, 2007 Author Report Share Posted February 13, 2007 oh sorry, yeah 1/O from batt. to dist. block, 4 gauge from dist. block to all 3 amps. the reason im askig this is because the amps have over 200A worth of fuses in them, 75 per alpine, and the jl says it pulls ~60A in the manual. and then fact. equipment and all the rest. just wondering if there is a more efficient way besides having to make a bracket for a 250A+ alt. because i have a small engine, (3.1L) and a cramped engine bay (96 chevy lumina) Quote Link to comment Share on other sites More sharing options...
civichatch Posted February 13, 2007 Report Share Posted February 13, 2007 im fairly new at car audio stuff but maybe adding a second battery in the rear. Quote System Specs: Alpine SWR-1542D 15" sub Sealed Subwoofer Box MTX mxa 6001 Class D 774watts RMS @ 2ohms MTX Bass Knob Pioneer 6.5's in doors MTX Thunderdome 6x9 in rear Stinger 1 Farad capacitor 80 amp stinger fuse BIG 3 in 4 gauge wire 4 gauge power/ground wire JVC MP3 CD Car Deck (KD-G320) 12 gauge Monster speaker wire to Sub 16 gauge Stinger speaker wire to doors Stinger Gold Plated Battery Terminals Link to comment Share on other sites More sharing options...
Chris Posted February 13, 2007 Report Share Posted February 13, 2007 im fairly new at car audio stuff but maybe adding a second battery in the rear. Very wise, my young apprentice. j/k Yes A 2nd battery is EXACTLY what you need. A 200 amp alt can probably charge 2 extras as well and Id bet money that ur bass gets louder too. REDTOPS FTW! Quote 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR. Link to comment Share on other sites More sharing options...
sean 371 Posted February 13, 2007 Report Share Posted February 13, 2007 x2 on a redtop in the back. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall Link to comment Share on other sites More sharing options...
ChevyBoy Posted February 13, 2007 Report Share Posted February 13, 2007 sand your grounds down to bare metal, use the biggest fuse for that wire you can afford, but check your gains and set it properly. that is not a lot of power really to be dimming. i assume all your power wires are 4 gauge to the amps? hes pulling almost if not more than 2k rms. thats definitely enough to cause dimming. Quote Link to comment Share on other sites More sharing options...
