I got an 04 ford f150!!! i was thinking a kinetik 2400 to run truck and upgrade the alt? but the ?? is is that gonna be enough??? i dont want to connect everything till i have everything so the first time i hear it its to its full potential i dont want to half ass it cause then im just gonna get disappointed
i can sell ohio gen alts for our truck. they arent cheap though.
DC Power has great alts for our trucks and as well as iraggi. good luck finding a dual bracket if you ever upgrade in the future though. You'll need a 6G plug on the alt.
pm me for info on the ohio gens.
and you can get kinetik 2400s on ebay for like $300 shipped.
Edited by dwright27
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
very pointless post. you just sent him to 3 different sites and he has no idea what to look for on any site.
A good battery would be Powermaster or Kinetik. Id say it be best to put either a powermaster d3100 or kinetik hc2400 in your trunk by your amp. These big batteries weight about 80 pounds and will run you anywhere from $300 to $400 shipped brand new.
http://www.powermastermotorsports.com/mobile_audio.html
or
http://www.kinetikaudio.com/
And just for a side note, the powermaster d3100 battery and the kinetik hc2400 are very compairable to each other BUT the powermaster d3100 battery is almost always cheaper in price, and will do more max amperage, and has a higher AH rating which are key things in batteries.
A great wire at a great price is the Knukoncepz Kolossus Fleks Kable. You are going to want to use 1/0 gauge wire for your power and ground.
It cost $3.25 per foot.
http://knukonceptz.com/productMaster.cfm?c...20Fleks%20Kable
or
if you want to save some more money, use their KLMX kable that costs $1.75 per foot. Note this wire does withstand as much current flow as the fleks kable, but with a big battery by your amp it will be fine.
http://knukonceptz.com/productMaster.cfm?c...ry=KLMX%20Kable
You can also get your fuse holders, fuses, rca cords, ring terminals from knukonceptz at a good price.
A upgraded alternator is a must have when you get into high powered stereos, your amp will drain a bit of juice but for the mean time you should be pretty good with the stock alt. A highoutput alternator is going to cost you the most. Depending on vehicle and size, youll be looking at $300-500 for a good high amperage alternator.
A few decent companies are:
Dc Power
http://www.dcpowerinc.com/
Mechman
http://mechman.com/store/index.php
Ohio Generator
http://www.ohiogen.com/
For the mean time if you decide to run the stock alternator, I will suggust a MLA module (missing link audio). This module plugs into your alternator, and will allow your alternator to charge at a higher voltage for keeping your batteries maintained to their fullest! They are only avaible for some vehicles so you would have to ask to know if one is availble.
These work on Stock and aftermarket alternators, so when you upgrade your alt, it will work with your new one, and your stock one.
They cost about $200-300 shipped.
http://www.missinglinkaudio.com/
I also want to suggust to you to do the "big 3 upgrade" under your hood.
You can find out what it is and how to do it here
http://www.stevemeadedesigns.com/board/ind...showtopic=13280
you read my mind!! thanks!!! i am in a budget right now so for now a kinetik 2400 but by the amp correct??? should i get another one to run da motor maybe smaller kinetik like 1400-1800 or just da one by da amp?? and that should hold up till i get an upgraded alt??
05 Ford F150- STOLEN!!!!4 AA Havocs 15s in a WALL4 Hifonics 2006ds1 kinetik 1800 in front4 kinetik 2400s n bakHifonics MaxxlinkAudiocontrol Epicenter2 runs 1/0 guage kicker hyperflexall other wires r knukonceptzTraded In05 Chevy SilveradoAscendant Audio 16 12s2 Mechman 320s1 Kinetik 1800 in front8 Kinetik 2400s n back4 2200 Audioques ampsLots of 0 gaugePioneer DeckAudio Control preampHifonics Maxxlink
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Audiocontrol Epicenter indash
All Rockford 1/0 & every cable in there
Jl audio xd 600/6
Rockford Fosgates Mids & highs
Built By Audiotistics!
o crap so its just not an easy swap from stock alt to upgraded alt?????
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
its a simple swap, you take the old alternator off, and reinstall the new alternator just as how you took the old one off.
Most the time its 3 or 4 bolts. Your alternator maybe in a hard to reach spot making it difficult tho. But you could be the judge of that by opening your hood.
I believe what dwright was referring to is doing a dual alt setup (2 alternators on 1 truck) which can be a pain becuase you got to pray that a alternator company makes a aftermarket bracket to bolt the 2nd alternator up too, or you got to custom fab your own bracket.
I dont recall you saying that you want to run 2 alternators unless i missed it somewhere, nor do I think you would need 2 alternators if you just got 1 good 250-300 amp alternator.
alright that sounds good!! need to order a new battery asap then and start lookin for a alt!! thanks
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
