Crump Posted March 17, 2009 Report Share Posted March 17, 2009 Is it 1. Fill all screw holes with body filler 2. Lay down some resin 3. Let Harden, Primer the wood 4. Sand 5. Use Spray Paint, (does it matter which kind) if so some links to examples at (menards, or home depot) Thanks Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs Link to comment Share on other sites More sharing options...
zfrerichs Posted March 17, 2009 Report Share Posted March 17, 2009 just get automotive primer from home depot and i dont resin my box itll ad some texture to the surface ill just put two or three coats on and sand it down and then yu can start laying primer just the way i do it Roseville, CA Link to comment Share on other sites More sharing options...
Crump Posted March 17, 2009 Author Report Share Posted March 17, 2009 just get automotive primer from home depot and i dont resin my box itll ad some texture to the surface ill just put two or three coats on and sand it down and then yu can start laying primer just the way i do it i got everything except the spray paint that makes it shine, any links? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs Link to comment Share on other sites More sharing options...
The Performer Posted March 17, 2009 Report Share Posted March 17, 2009 http://www.stevemeadedesigns.com/board/ind...st&p=502970 Follow from that post to the VERY end of the thread and read all the steps I took with the spray paint. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
zfrerichs Posted March 17, 2009 Report Share Posted March 17, 2009 you could always get a clear coat from home depot too or if you want to be a little more pro about it just go to your local paint store and they can help you out more. Roseville, CA Link to comment Share on other sites More sharing options...
Crump Posted March 17, 2009 Author Report Share Posted March 17, 2009 http://www.stevemeadedesigns.com/board/ind...st&p=502970Follow from that post to the VERY end of the thread and read all the steps I took with the spray paint. yeah man that really helps, so waxing it gives it that oh so sexy shine? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs Link to comment Share on other sites More sharing options...
The Performer Posted March 17, 2009 Report Share Posted March 17, 2009 yeah man that really helps, so waxing it gives it that oh so sexy shine? Yes, as a final step. Put on a clear coat, but you will never get a pro finish straight from the can. You want to do a good 3-4 coats of clear if you need, (I did not need a clear on my box) But I would recommend it if you've never done paint jobs like this. Then after a good few days for the clear coat to cure you can start wetsanding with high grit to get rid of the orange peel. Start with 1000 to get the surface equal, then do 2000 to get the swirls out from the 1000, then hit it with a polishing compound a few times, then wax many more times. I did my chevy bowtie emblem this way, so check that out as well. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
