hey everyone i got a question for all of ya. Im going to be upgrading my sub in the near future and was wanting some input on wat i should get. Im looking for 1 15 inch dual 4 ohm sub. I will be running a MTX mxa 6001 amp rated at 774 watts rms at 2 ohms. It will be going in a sealed box but may change to ported. I have limited space or i would be going for 2x15's or 18's. Im willing to spend $400-$500 Canadian thanks for reading and any input would be appreciated.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
what do you guys think about this sub.
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14956
System Specs:
MTX Bass Knob
80 amp stinger fuse
really how do u wire dual 1 ohm into 2 ohm?? i no of wiring dual 4 ohm into 2 ohm.
System Specs:
MTX Bass Knob
80 amp stinger fuse
you wire it in series...pos off amp to pos on first coil, neg off first coil to pos on second coil, neg on second coil to neg on amp.  that'll double resistance.  I'd recommend either of the ones posted above.  I was about to recommend the R, but both that and the SSD would work real well off that amp.
edit: try sonicelectronix.com for the type r, its $45 cheaper.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
coil one: wire the negative to the positive on coil two and wire the positive to the negative on coil two...then from coil two run the positive to the positive on the amp and the same with the negative...
i likes me some audio stuff...
This isn't super clear, I think we're saying the same thing.  But I think you have extra (unnecessary) wires thrown in there.
Subwoofer Wall
I understand exactly wat your saying. Now wat wil the advantage be in the end if i run a dual 1 ohm into 2 ohms,or if i run a dual 4 ohm into 2 ohms. Wats the benefit of running dual 1 ohm into 2 ohms??
System Specs:
MTX Bass Knob
80 amp stinger fuse
pos off amp to pos on first coil' date=' neg off first coil to pos on second coil, neg on second coil to neg on amp.  that'll double resistance.[/color'] = Total resistance.  R1, R2, and R3 being your different resistances.  When working with resistances of the same value, it becomes super simple.
Subwoofer Wall
k thanks alot.
System Specs:
MTX Bass Knob
80 amp stinger fuse
