Minimum Height For 18" Btl
Guest KyleCannon
Hey guys,
Looking at getting a 18" BTL in the future... what is the minimum height of an enclosure with a 18" BTL to see if it will go in my trunk easily.
Thanks!
BTL18
DUAL 1 | DUAL 2
Fs: 31.9 Hz | 31.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 6.26 | 6.42
Qes: .26 | .24
Qts: .24 | .023
Mms: 313g | 329g
Sd: 1210cm^2 | 1210cm^2
Vas: 163.1 l | 163.1 l
Spl: 94.9dB 1W/1m | 94.9dB 1W/1m
Bl: 18.3 N/A | 27.2 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-10cuft | 5-10cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 10.250” | 10.250”
Displacement: 0.26cuft | 0.26cuft
Product code: 00218
Price: $ 414.00
DC.jpgDC POWER
Guest KyleCannon
I don't need the mounting depth I need the height from the bottom of the cone to the top. ;)
is that what the sub OD is 18.5 inches? just didn't know what OD stood for.
Edited by KyleCannon
just add a couple inches. make it 15 to be safe. with box and sub.
My New Build checklist:
(3) 18'' btl fully loaded d2
Guest KyleCannon
an 18" sub cone and make the height of the box 15" ?
Sorry, I am just trying to make sure here because I am going to start messing around in sketchup
the mounting depth is going from the ring of the cone to the bottom of the magnet... so add 5" from that, is where he got 15 your thinking of the diameter of the sub which is 18"
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Guest KyleCannon
Alright So if the diameter of the sub is 18 inches, then i would need to make the enclosure about 20" high to put that baby in a box?
Sub ID is Inner Diameter (size of the hole)
and sub OD is Outer Diameter (outside of the basket)
so 16.75+1.5 = 18.25" smallest total height of the box if the woofer is completely upright
-Drew
Edited by Noobtastic14
uhoh_45 said:
