well i'm gonna need trunk room and i'm gonna take out the last seats anyways. but i wanna know, Tahoe or Suburban?? i was thinking the suburban because it has more room but the tahoe is a nice truck and i'm sure i can fit 4 15"s in it. soo which truck??
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
Tahoe is def legit for 4 15s.
suburban = more gas...
it boils down to if u want more room or not.
Eclipse cd7000
that's what i was worried about, was the gas. and as long as i can put 4 15"s in the truck and still have a set of backseats, it's cool with me.
2 HFX 12's
Audiopipe APSM-1300
Get a Tahoe, I have one, and it has more than enough room. A Burb is only like a foot longer, and as far as gas tanks go, the Burb might hold more, (depends on what size tank!) but you will go further with a bigger tank! Go with a Hoe! IMO
"loud 'cause its clipped like a 7yr olds buzz cut" -Decaf
"unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
cool. thanks man.
2 HFX 12's
Audiopipe APSM-1300
btw, what do you have in yours??
Ugh...well, I HAD two 12s (KICKER) in a PRO BOX. NOW, I have two 15s (KICKER CVRS) in a craptastic prefab box, that I bout from a guy I work with, for $200. ( helping him out, he got laid off! They are only 6 months old.) I am going to build a box next weekend....I HOPE!
pretty nice. what's gonna power them?
2 HFX 12's
Audiopipe APSM-1300
I HAD, but can't find an older 1200 watt KICKER amp, but like I say, can't find it, that....or somebody jacked it out of the garage! I'll probabley go with a KICKER SX900.2, specs:
425 watts RMS x 2 at 2 ohms (850 watts RMS x 1 bridged at 4 ohms)
variable high-pass (10 Hz - 16 kHz, 36 dB/octave) and low-pass (30 Hz - 20 kHz, 36 dB/octave) filters
4 memory banks store intricate EQ cut/boost, low-pass crossover, phase, bass boost, sub-sonic filter, and compression settings.
I know a guy with a audio shop in town, I can get it for like $300 or less.
