How big is each chamber? Also yes I would add another 1 or even 2 4" ports for each sub. I have 3 4" aeroports for each 15" in my car. I would say that 3 per 18 will work much better and be louder. The only thing is it will tune the box higher. Let me know how much airspace you have and I'll tell you how long to make the ports to tune where you want. If it were me I'd tune it to 37 hz.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
Here r the numbers 60X24X20 thats around 9^ft per chamber. The other 4 ports are 18 so i guess i should do 2 more @ 18 one in each chamber. Man the box hit so hard i shook the coffee in our local wawa the manage came running out and said can u not play ur music that loud until he saw the uniform HA HA HA lmao.
You gonna double baffle?
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Add two more 4" ports per chamber. Make each of them 18" long and that will tune the box to 32hz. If you want to tune higher your going to need to cut some length off of the ports. If you want to tune to 37 like I reccomended you'll need to make the ports 12.25" long each. I reccomend that you definately do at least 2 more ports per sub, so a total of 4 more ports cause if you only do one more per sub you'll be tuned at 28hz with them at 18" long.
1 XS Power D3100
Audio Control LC6i
Stock Deck
the correct after further investigation each chamber is 7.2^3 per woofer. Currently have 2, 4inch ports per chamber @ 18 inches long. So what u are saying is add another port for each chamber 4 inch abs @ 18 inchs. The only thing is I only have room for one more port. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/mad.gif Hope i don't need more.
  • Who's Online   1 Member, 0 Anonymous, 1007 Guests (See full list)
