and i'm there but there is no explorer.exe or anything. soo what???
Check c:\windows\system32\ and see if explorer.exe is there.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
You can probably do a system restoration if you have a Windows XP disc with the Key. I'm a system administrator for the Marine Corps and your problem (only because I'm not there to see it) sounds like it needs it. It takes a while, but it's a failsafe and 95% guaranteed to fix most problems.
EDIT: Ah, didn't read all the posts. Seems you're getting it worked out.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
nope. no explorer.exe. idk WHAT it did to my system but it messed it up for sure.
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
Neo_frog got it right for ya now, you'll have to to a system restore off the installation CD
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
2 problems. 1. don't have the XP cd. idk where it went too. 2. i'm running windows black (blak. which ever you say) i don't want to install or put XP back on. lol.
2 HFX 12's
Audiopipe APSM-1300
if i have too, i will just take it back to him. but idk what else to do but even if i did want to put it on, i don't have a CD. it sucks BIG time.
2 HFX 12's
Audiopipe APSM-1300
If I'm not mistaken isn't Windows Black just a hacked version of XP SP2?
[email protected]
not sure exactly. i know it's not completely out in the states yet but it is used over in germany and that area mostly. not a bad running system. but it uses alot of vista in it.
2 HFX 12's
Audiopipe APSM-1300
Did a little research and there are XP and Vista Black versions. But yeah, if you don't have the CDs you're most likely out of luck. I only say that because I'm only getting info from posts and it's a pain troubleshooting a system you may not be familiar with over text...
[email protected]
it's fine. i'll just take it back to the guy and say it was treatfires fault. lol. which it pretty much was. and i have the vista black version. nice running system though.
2 HFX 12's
Audiopipe APSM-1300
