Nice, looking good, but why it the port just a square?
Just the design i'm working with at the present time :)
Dats alotta box! I Like It!!! :)
Woot for more pictures!
Let me upload them for photobucket and i'll post some :)
looking great! any internal bracing? any plans on simply removing the rear seats?
NEUMAN
See the metal rods in the photos? Thats what i'm using for bracing :)
For a daily i wont remove the rear seats. Basicly if i do i can get my defected for it (non-roadworthey) and to get it roadworthey again it would require too much work. So i will definitely remove the seats at Meets and Comps though...
looks sick, can't wait to see some vids! do work son!
I'm pretty sure there will be some Vids coming on Sunday night :)
Give me a few mins to source up some of my old pics of my door trims.
Gossip Girl xoxo
1994 Suzuki Vitara (Escudo)
[unreveiled Subwoofers] - 1,500Wrms, triple stack motor. 15" x 2
DD M1A x 2
10.5 cubes in a tiny car ;)
Here is a few pics as asked.
Here is me in comparison to the box
Posted Image
This is my very first set up in the Vitara
Posted Image
Here is my second ever set-up in the Vitara. Boy was it crap.... Did like 134 @ 5Xhz or something.
Posted Image
Here is my little battery
Posted Image
I was building this to go onto the tailgate, didn't end up happening :)
Posted Image
And here is some pics of my doors. Built by me, apart from the vinyl (which the guy did a shit job.) Note they were super smooth and no jagged spots when they were covered. Just didn't have any pictures.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
DD M1A x 2
Well, well, well....
Everything is hooked up and currently running off my little M1 at around 400W RMS @ 2ohm per sub.
Managed to get 134.8 @ 33hz and 131.7 @ 21hz on sunday. No tuning and wayyyyy underpowered, but I am not expecting numbers as i want this lowwww.... this just means i need to get my port re-designed (low :) ) once the other amp arrives... (another M1A, so that will make 'around' 1.5kwRMS each woofer).
It loves the lows and pushes the doors right out, if its light when i get home i'll get some vids up.
Now the other amp is organised i need to get hold of some nice big batteries and chuck two of them in the back and then be able to run 2 0AWG runs from batts -> amps.
Bill
DD M1A x 2
  • 4 weeks later...
Hey guys,
We'll i've been busy.
Got a few new toys, like....
Another M1a
A 150ah Battery
13mtrs of 70mm2 cable
Accessory
Fines...
Pics as follows....
Here is one M1 getting the wire test fitted
Posted Image
Posted Image
Posted Image
Here is making some grounding points
Posted Image
Posted Image
Posted Image
Here is some battery fitting and cabling, I actually have two of these batteries. But both won't fit in the car... :(
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
DD M1A x 2
Here is my amplifier rack (this is not where it is located...)
Posted Image
Posted Image
Posted Image
Here it is with gear in, before it was hooked up. It now needs trim panels.
Posted Image
Posted Image
If you love it or hate it, leave a comment and let me know what you think :)
Bill
DD M1A x 2
looks good.
why not just remove the rear seats?
And the fact that i'm the kind of person that gets bored REALLY easy, which means i'll end up taking it out in the next few weeks and change something. I'm the kind of person that can't make up my mind if you know what i mean.....
As quoted, to get this thing roadworthy again (if it were to get un-roadworthy) would be too much hassle and too much money :(.
Keep the love flowing :)
DD M1A x 2
that wire looks sexy with that little amp good job on the build
R.I.P!
(Nov-29-2009)
92 explorer
current build
